Ana içeriğe geç
Acer Chromebook 15 C910-C453 Fan Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: adım 1, 2 resimden 1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Fan Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Fan Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 C910-C453 Fan Replacement: adım 3, 2 resimden 2.
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Fan Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 C910-C453 Fan Replacement: adım 4, 2 resimden 2.
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Fan Replacement: adım 5, 1 resimden 1.
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Fan Replacement, Fan: adım 6, 1 resimden 1.
    • Unscrew the following Phillips #1 screws:
    • Two black 4mm Phillips screws located on the fan.
    • Four copper 4mm Phillips screws located on the heat sink.
  7. Acer Chromebook 15 C910-C453 Fan Replacement: adım 7, 1 resimden 1.
    • Disconnect the fan from the motherboard by pulling down on the wire connector with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Fan Replacement: adım 8, 1 resimden 1.
    • Lift up the fan while unwrapping the black and white wires from around the fan.
    • Do not pull wires off of the motherboard.
    • Remove the fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Rakestraw
419 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G1
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 490
