Ana içeriğe geç
Acer Chromebook 15 C910-C453 Speakers Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: adım 1, 2 resimden 1. Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 3, 2 resimden 2.
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 4, 2 resimden 2.
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 5, 1 resimden 1.
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: adım 6, 3 resimden 1. Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: adım 6, 3 resimden 2. Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: adım 6, 3 resimden 3.
    • Before beginning hard drive replacement, the back cover should be taken off and the battery removed to ensure no power is connected.
    • Carefully eject the black ribbon from the white base by squeezing inward at the base and gently pulling backwards.
    • Gently pull black ribbon out.
  7. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 7, 3 resimden 1. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 7, 3 resimden 2. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 7, 3 resimden 3.
    • Disconnect the black wires where the speakers are connected to the motherboard by pulling down on both sides with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 8, 2 resimden 1. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 8, 2 resimden 2.
    • Gently pull the right speaker, FYHZRF-R, upward, unlatching it from its 2 rubber joints.
    • Repeat with left speaker, FYHZRF-L.
  9. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 9, 2 resimden 1. Acer Chromebook 15 C910-C453 Speakers Replacement: adım 9, 2 resimden 2.
    • Lift left and right speakers up and untangle the connecting wire from the metal notches.
    • Remove the speakers.
Sonuç
Jacob Rakestraw
419 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G1
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 611
