Ana içeriğe geç
Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 1 resimden 1.
    • Place the device on a flat surface with the bottom facing upwards.
  2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 2, 2 resimden 1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
  3. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
    • Be careful not to damage or crack the back cover of the device.
  4. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Carefully remove the back cover.
  5. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 5, 2 resimden 1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Locate the Wi-Fi card. It will be white chip beside the motherboard.
    • Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
  6. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 6, 3 resimden 1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 6, 3 resimden 2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: adım 6, 3 resimden 3.
    • Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
    • Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
    • Have your new replacement Wi-Fi card ready to place back in the slot.
Sonuç
Avinesh Mohanaranjan
183 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 959
