Ana içeriğe geç
Acer Chromebook 15 CB5-571-C09S Back Cover Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: adım 2, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: adım 2, 2 resimden 2.
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: adım 4, 2 resimden 2.
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sakiynah Howard
1.000 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 652
