Ana içeriğe geç
Acer Chromebook 15 CB5-571-C09S Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 2, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 2, 2 resimden 2.
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 4, 2 resimden 2.
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: adım 5, 3 resimden 1. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: adım 5, 3 resimden 2. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: adım 5, 3 resimden 3.
    • The battery is the large black rectangle located in the bottom center of the device.
    • Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
  6. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 6, 3 resimden 1. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 6, 3 resimden 2. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery connector from the motherboard using two plastic opening tools.
    • The battery connector is the white "plug" that connects the battery to the motherboard with rainbow colored wires attached to it.
    • Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
  7. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 7, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Battery Replacement: adım 7, 2 resimden 2.
    • Once the battery has been disconnected from the motherboard it can easily be removed from the device.
    • Grab the top edge of the battery and carefully pull it up and out of the device towards you.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Sakiynah Howard
1.000 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G3
3 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do you get the plastic opening tools
Kelly Robledo - Yanıt
Instructions were perfect. Used a putty knife to pry off the back
Naomi Harrison - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 4,210
