Ana içeriğe geç
Acer Chromebook 15 CB5-571-C09S Screen Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: adım 1, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Wedge one of the plastic opening tool in the inside of the screen cover and run it along the inside perimeter of the screen.
  2. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 2, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 2, 2 resimden 2.
    • Wedge the plastic opening tool inside the back of the screen cover and run along the perimeter of the screen.
  3. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 3, 2 resimden 2.
    • Remove the screen cover from the screen.
    • Pry off a pair of small covers at the back of the hinges first.
    • Carefully grab the edges of the screen cover from opposite ends and pull off the screen towards you.
  4. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 4, 3 resimden 1. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 4, 3 resimden 2. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 4, 3 resimden 3.
    • Unscrew the four 3 mm PH00 Phillips head screws located on the inside corners of the screen.
    • Be sure to unscrew the inner screws attached to the screen and not the outer screws.
  5. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 5, 1 resimden 1.
    • Grab the edges of the screen and pull it out towards you.
    • Do not try to remove the screen from the device at this point. There are still connections in the back that need to be disconnected before the screen can be removed.
  6. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 6, 1 resimden 1.
    • Take out screen from top part of the device and lay it down flat on the key board.
  7. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 7, 3 resimden 1. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 7, 3 resimden 2. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 7, 3 resimden 3.
    • Remove the screen connector from the back of the screen.
    • The screen connector is a "plug" that is connected to the back of the screen with a grey wire.
    • The screen connector is attached to the back of the screen with a sticker.
    • Peel and remove the sticker connecting the screen connector to the screen.
  8. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 8, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Screen Replacement: adım 8, 2 resimden 2.
    • Lift the screen back up from the keyboard and remove from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sakiynah Howard
1.000 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G3
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Where can I find the replacement screen?
Riccardo Rigamondi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 2,155
