Ana içeriğe geç
Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 2, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 2, 2 resimden 2.
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 4, 2 resimden 2.
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: adım 5, 3 resimden 1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: adım 5, 3 resimden 2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: adım 5, 3 resimden 3.
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 6, 2 resimden 1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: adım 6, 2 resimden 2.
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sakiynah Howard
1.000 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G3
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 3,353
