Giriş
This guide will walk you through replacing the SSD in your Acer Chromebook 15 CB5-571-C09S.
Neye ihtiyacın var
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
