Ana içeriğe geç
Acer Chromebook C710-2833 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Chromebook C710-2833 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Hard Drive Replacement: adım 2, 2 resimden 1. Acer Chromebook C710-2833 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 Hard Drive Replacement: adım 3, 2 resimden 1. Acer Chromebook C710-2833 Hard Drive Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Locate the hard drive.
    • Locate the four 3 mm Phillips #00 screws on each corner of the hard drive.
    • Take your driver with the PH00 bit attached and unscrew all four screws.
    • Place the screws off to the side for now.
  5. Acer Chromebook C710-2833 Hard Drive Replacement: adım 5, 2 resimden 1. Acer Chromebook C710-2833 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Once all the screws are out, gently pull the hard drive out as pictured.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Latorre
558 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Nance Fall 2017 USF Tampa, Team S1-G6, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 49
Her zaman: 1,519
