Giriş
With use, the SD card reader of your laptop may stop reading SD cards. The SD card reader might need to be replaced if your computer does not recognize when a SD card is inserted. It is a good idea to attempt inserting multiple SD cards to ensure that the SD card reader is the problem, not the SD card itself. Replace the reader with this guide.
Neye ihtiyacın var
Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
