Ana içeriğe geç
Acer Chromebook C710-2856 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Chromebook C710-2856 Hard Drive Replacement, Removing Back Cover: adım 1, 2 resimden 1. Acer Chromebook C710-2856 Hard Drive Replacement, Removing Back Cover: adım 1, 2 resimden 2.
    • Remove the one 4.3mm Phillips #1 screw holding the back cover on.
  2. Acer Chromebook C710-2856 Hard Drive Replacement, Unscrewing the Drive: adım 2, 1 resimden 1.
    • Remove the four 2.8mm Phillips #000 screws holding the drive onto the case.
  3. Acer Chromebook C710-2856 Hard Drive Replacement, Uncovering the Pins: adım 3, 1 resimden 1.
    • Gently pull the foam protector away from the pin connectors
  4. Acer Chromebook C710-2856 Hard Drive Replacement, Disconnecting the Drive: adım 4, 2 resimden 1. Acer Chromebook C710-2856 Hard Drive Replacement, Disconnecting the Drive: adım 4, 2 resimden 2.
    • Gently pull the drive up and away to disconnect the hard drive from its seat
  5. Acer Chromebook C710-2856 Hard Drive Replacement, Removed Drive and Pieces: adım 5, 1 resimden 1.
    • Fully removed hard drive, screws, and foam cover
Sonuç
Josh Rowell
146 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G5, Remmell Fall 2017 USF Tampa, Team S6-G5, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S6G5
7 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 333
