Giriş
Use this guide to replace the Wi-Fi card in your device.
Neye ihtiyacın var
Flip the device over and remove the 4.3 mm screw using a Phillips #1 screwdriver.
Remove the back cover.
Using the Phillips #1 screwdriver, remove the screw from the Wi-Fi card.
Carefully remove the piece of tape to allow for more room to remove the Wi-Fi card.
Use the blue plastic opening tool to lift and remove the Wi-Fi card from its socket.
Neredeyse bitti!
Sonuç
