Ana içeriğe geç
Acer Chromebook C710-2856 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Back Cover: adım 1, 2 resimden 1. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the device over and remove the 4.3 mm screw using a Phillips #1 screwdriver.
    • Remove the back cover.
  2. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: adım 2, 3 resimden 1. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: adım 2, 3 resimden 2. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: adım 2, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the screw from the Wi-Fi card.
    • Carefully remove the piece of tape to allow for more room to remove the Wi-Fi card.
    • Use the blue plastic opening tool to lift and remove the Wi-Fi card from its socket.
  3. Acer Chromebook C710-2856 Wi-Fi Card Replacement: adım 3, 3 resimden 1. Acer Chromebook C710-2856 Wi-Fi Card Replacement: adım 3, 3 resimden 2. Acer Chromebook C710-2856 Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Use the blue plastic opening tool and carefully remove the connectors from the Wi-Fi card.
  4. Acer Chromebook C710-2856 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Acer Chromebook C710-2856 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Remove the Wi-Fi card.
Sonuç
John
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G5, Remmell Fall 2017 USF Tampa, Team S6-G5, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S6G5
7 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 399
