Ana içeriğe geç
Acer Chromebook C720 Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720 Battery Replacement, Battery: adım 1, 3 resimden 1. Acer Chromebook C720 Battery Replacement, Battery: adım 1, 3 resimden 2. Acer Chromebook C720 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using a Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Battery Replacement: adım 2, 2 resimden 1. Acer Chromebook C720 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the two 3mm screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook C720 Battery Replacement: adım 3, 2 resimden 2.
    • Disconnect the 8-pin ribbon cable from the motherboard.
    • Remove the battery pack from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Benjamin Rahman
517 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G5, Harley Spring 2019 IUPUI, Team S2-G5, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G5
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,064
