Ana içeriğe geç
Acer Chromebook C720 Solid State Drive (SSD) Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): adım 1, 3 resimden 1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): adım 1, 3 resimden 2. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): adım 1, 3 resimden 3.
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: adım 2, 3 resimden 1. Acer Chromebook C720 Solid State Drive (SSD) Replacement: adım 2, 3 resimden 2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: adım 2, 3 resimden 3.
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: adım 3, 2 resimden 1. Acer Chromebook C720 Solid State Drive (SSD) Replacement: adım 3, 2 resimden 2.
    • Gently remove the SSD from the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Benjamin Rahman
517 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G5, Harley Spring 2019 IUPUI, Team S2-G5, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G5
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - Yanıt
Mi duda es como instalo Chrome os a la ssd nueva
José De Jesús Lopez Guillen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 151
Her zaman: 5,496
