Giriş
This guide describes how to properly remove the battery of the Acer Chromebook C720-2103. It can be referenced for a temporary removal, while replacing another component, or for the batteries replacement.
A battery replacement is recommended if the device no longer holds a charge or if the battery is faulty.
- The plastic outer casing is easy to damage during removal. Take your time and be careful.
- Make sure the device is powered off during this replacement. There is a possibility of electrocution.
Neye ihtiyacın var
Shut the device off.
Turn the device over so the bottom is facing up.
Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
