Ana içeriğe geç
Acer Chromebook C720-2103 Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: adım 1, 2 resimden 1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 2, 1 resimden 1.
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 3, 1 resimden 1.
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 4, 2 resimden 1. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 4, 2 resimden 2.
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 5, 2 resimden 1. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 5, 2 resimden 2.
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: adım 6, 1 resimden 1.
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 7, 3 resimden 1. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 7, 3 resimden 2. Acer Chromebook C720-2103 Solid State Drive Replacement: adım 7, 3 resimden 3.
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Holt
633 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 UMass Dartmouth, Team S66-G3, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S66G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 276
