Ana içeriğe geç
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
Neye ihtiyacın var
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: adım 1, 2 resimden 1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: adım 1, 2 resimden 2.
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: adım 3, 2 resimden 1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: adım 4, 2 resimden 1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: adım 5, 1 resimden 1.
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: adım 6, 2 resimden 1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: adım 6, 2 resimden 2.
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: adım 7, 3 resimden 1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: adım 7, 3 resimden 2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: adım 7, 3 resimden 3.
    Satın Al
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
Sonuç
Jessica Beckford
527 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S15G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 185
