Giriş
This guide will provide you with simple and clear steps on how to replace/remove the keyboard on your Acer Chromebook C720-2420.
Neye ihtiyacın var
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
Remove the six 4.7 mm Phillips screws that secure the fan.
Remove the speakers located on both left and right bottom corners of the Chromebook with a plastic opening tool.
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Huh? This doesn’t tell how to replace the keyboard.
After the last step unscrew the 3 screws at the top of the device holding the display assembly to the top portion, then bend those up and you can pull the whole cover with the keyboard and touchpad off and slide the new one in.
