Ana içeriğe geç
Acer Chromebook C720-2420 Memory Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2420 Memory Replacement, Back Cover Replacement: adım 1, 2 resimden 1. Acer Chromebook C720-2420 Memory Replacement, Back Cover Replacement: adım 1, 2 resimden 2.
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Memory Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Memory Replacement, Memory: adım 3, 2 resimden 1. Acer Chromebook C720-2420 Memory Replacement, Memory: adım 3, 2 resimden 2.
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  4. Acer Chromebook C720-2420 Memory Replacement: adım 4, 2 resimden 1. Acer Chromebook C720-2420 Memory Replacement: adım 4, 2 resimden 2.
    • Pull out the SSD.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jessica Beckford
527 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S15G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 420
