Ana içeriğe geç
Acer Chromebook C720-2827 RAM Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2827 RAM Replacement, Back Panel Assembly: adım 1, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement, Back Panel Assembly: adım 1, 2 resimden 2.
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 RAM Replacement: adım 2, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 2, 2 resimden 2.
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 RAM Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 RAM Replacement: adım 4, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 4, 2 resimden 2.
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 RAM Replacement: adım 5, 1 resimden 1.
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 RAM Replacement, Speakers: adım 6, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement, Speakers: adım 6, 2 resimden 2.
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 RAM Replacement: adım 7, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 7, 2 resimden 2.
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 RAM Replacement, Solid State Drive: adım 8, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement, Solid State Drive: adım 8, 2 resimden 2.
    • Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 RAM Replacement: adım 9, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 9, 2 resimden 2.
    • Carefully pull out the solid state drive using two fingers.
  10. Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: adım 10, 3 resimden 1. Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: adım 10, 3 resimden 2. Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: adım 10, 3 resimden 3.
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  11. Acer Chromebook C720-2827 RAM Replacement: adım 11, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 11, 2 resimden 2.
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  12. Acer Chromebook C720-2827 RAM Replacement: adım 12, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 12, 2 resimden 2.
    • Pull the blue tab on the ribbon cable to remove it.
  13. Acer Chromebook C720-2827 RAM Replacement: adım 13, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 13, 2 resimden 2.
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  14. Acer Chromebook C720-2827 RAM Replacement: adım 14, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 14, 2 resimden 2.
    • Position the spudger under the switch.
  15. Acer Chromebook C720-2827 RAM Replacement: adım 15, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 15, 2 resimden 2.
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
  16. Acer Chromebook C720-2827 RAM Replacement, Motherboard: adım 16, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement, Motherboard: adım 16, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the four 3.0mm screws.
    • Loosen the six 3.0mm CPU screws using the Phillips #1 screwdriver.
    • The six 3.0mm CPU screws do not come out of the motherboard.
  17. Acer Chromebook C720-2827 RAM Replacement: adım 17, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 17, 2 resimden 2.
    • Grab the wire for the two pin connector.
    • Pull the wire to disconnect it from the motherboard.
  18. Acer Chromebook C720-2827 RAM Replacement: adım 18, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 18, 2 resimden 2.
    • Place the back of the spudger under the black wire that connects the wireless card to the motherboard.
    • Flick the spudger up to disconnect the cable from the motherboard.
  19. Acer Chromebook C720-2827 RAM Replacement: adım 19, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 19, 2 resimden 2.
    • Place the back of the spudger under the white coaxial antenna wire that connects the wireless card to the motherboard.
  20. Acer Chromebook C720-2827 RAM Replacement: adım 20, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 20, 2 resimden 2.
    • Take both wires and unravel them from the CPU fan.
  21. Acer Chromebook C720-2827 RAM Replacement: adım 21, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 21, 2 resimden 2.
    • Firmly grasp the red, yellow, and white cords with two fingers.
    • Pull the cords to unplug it.
  22. Acer Chromebook C720-2827 RAM Replacement: adım 22, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 22, 2 resimden 2.
    • Position the spudger under the switch of the big ribbon cable.
  23. Acer Chromebook C720-2827 RAM Replacement: adım 23, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 23, 2 resimden 2.
    • Grab the blue tab of the ribbon cable.
    • Pull on the blue tab to disconnect the ribbon cable.
  24. Acer Chromebook C720-2827 RAM Replacement: adım 24, 3 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 24, 3 resimden 2. Acer Chromebook C720-2827 RAM Replacement: adım 24, 3 resimden 3.
    • Grab the red and black cable near the display cables, this is the cable to the other two pin connector.
    • Pull on the wire to disconnect it from the motherboard.
    • Flip the wire and the connector up to move it out of the way.
  25. Acer Chromebook C720-2827 RAM Replacement: adım 25, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 25, 2 resimden 2.
    • Position the spudger under the switch for the smaller ribbon cable.
    • Flick the spudger up to flip the smaller switch up.
  26. Acer Chromebook C720-2827 RAM Replacement: adım 26, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 26, 2 resimden 2.
    • Grab the blue tab on the ribbon cable.
    • Pull on the tab to disconnect the ribbon cable from the motherboard.
  27. Acer Chromebook C720-2827 RAM Replacement: adım 27, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 27, 2 resimden 2.
    • Position the back of the spudger at the edge of the tape that holds the display cable in.
    • Peel the tape back so it is out of the way.
  28. Acer Chromebook C720-2827 RAM Replacement: adım 28, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 28, 2 resimden 2.
    • Position the back of the spudger on the display cable.
    • Push the display cable out using the back of the spudger.
  29. Acer Chromebook C720-2827 RAM Replacement: adım 29, 2 resimden 1. Acer Chromebook C720-2827 RAM Replacement: adım 29, 2 resimden 2.
    • Lift up the CPU fan to ensure that no wires are tangled. If the black and white wires are tangles please repeat step 5.
    • Lift up the other end of the motherboard to completely remove the motherboard.
  30. Acer Chromebook C720-2827 RAM Replacement, RAM: adım 30, 1 resimden 1.
  31. Acer Chromebook C720-2827 RAM Replacement: adım 31, 1 resimden 1.
    • Put the new RAM in place of the old RAM.
    • Carefully solder the new RAM into place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kennedy Morales
655 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Peak Fall 2018 UMass Dartmouth, Team S2-G3, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G3
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Can you link the ram parts?
Tyler OHara - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 70
Her zaman: 3,399
