Ana içeriğe geç
Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: adım 1, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: adım 1, 2 resimden 2.
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 2, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 2, 2 resimden 2.
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 4, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 4, 2 resimden 2.
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 5, 1 resimden 1.
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: adım 6, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: adım 6, 2 resimden 2.
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 7, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 7, 2 resimden 2.
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: adım 8, 3 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: adım 8, 3 resimden 2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: adım 8, 3 resimden 3.
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 9, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 9, 2 resimden 2.
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  10. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 10, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 10, 2 resimden 2.
    • Pull the blue tab on the ribbon cable to remove it.
  11. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 11, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 11, 2 resimden 2.
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  12. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 12, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 12, 2 resimden 2.
    • Position the spudger under the switch.
  13. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 13, 2 resimden 1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: adım 13, 2 resimden 2.
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jason Bechtold
611 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G7, Julie Fall 2017 UMass Dartmouth, Team S4-G7, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G7
1 Üye
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 303
