Ana içeriğe geç
Acer Chromebook C720-2844 Display Screen Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: adım 1, 2 resimden 1. Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: adım 1, 2 resimden 2.
    • Unscrew and remove the 1 cm Phillips #00 screws from motherboard.
    FixBot'a Sor
  2. Acer Chromebook C720-2844 Display Screen Replacement: adım 2, 2 resimden 1. Acer Chromebook C720-2844 Display Screen Replacement: adım 2, 2 resimden 2.
    • Unscrew and remove the 1 cm Phillips #00 screw that secures the solid state drive.
    • Lift and pull towards you to remove.
    FixBot'a Sor
  3. Acer Chromebook C720-2844 Display Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the 3 cables shown by pulling back evenly from both ends.
    FixBot'a Sor
  4. Acer Chromebook C720-2844 Display Screen Replacement: adım 4, 2 resimden 1. Acer Chromebook C720-2844 Display Screen Replacement: adım 4, 2 resimden 2.
    • Unlock the cables shown by lifting the white tab on each.
    • Pull back on the blue tab to remove each cable from the motherboard.
    FixBot'a Sor
  5. Acer Chromebook C720-2844 Display Screen Replacement: adım 5, 2 resimden 1. Acer Chromebook C720-2844 Display Screen Replacement: adım 5, 2 resimden 2.
    • Remove the motherboard by shifting to the left and lifting up.
    • Unhook the black and white cables from underneath the motherboard.
    FixBot'a Sor
  6. Acer Chromebook C720-2844 Display Screen Replacement: adım 6, 1 resimden 1.
    • Unscrew and remove the 1 cm Phillips #00 screws from the display brackets.
    • Lift bracket to detach from the screen.
    FixBot'a Sor
  7. Acer Chromebook C720-2844 Display Screen Replacement: adım 7, 1 resimden 1.
    • Separate the screen from the shell.
    FixBot'a Sor
Sonuç
Derek Zevalkink
145 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Pee Spring 2022 Gateway, Team 1-2, Pee Spring 2022 üyesi
GCC-PEE-S22S1G2
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 337
