Ana içeriğe geç
Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement, Heatsink and Cooling Fan: adım 1, 1 resimden 1.
    • Unscrew and remove the four 1 cm Phillips #00 screws from the heatsink.
  2. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Proceed to unscrew and remove the two 1 cm Phillips #00 screws holding the fan in place.
  3. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: adım 3, 3 resimden 1. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: adım 3, 3 resimden 2. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Remove the fan connection from the motherboard.
    • Disconnect the black & white cables.
    • Remove the cables from the hooks on the fan housing.
  4. Acer Chromebook C720-2844 Heatsink and Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Lift up to remove the cooling fan and heatsink.
Sonuç
Christian Madrigal
229 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Pee Spring 2022 Gateway, Team 1-2, Pee Spring 2022 üyesi
GCC-PEE-S22S1G2
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 110
