Giriş
Use this guide to replace the motherboard for your device.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Use a Phillips head screw driver to remove the 13 screws in these locations.
Unscrew screw holding SSD card in place.
Slide out the SSD card towards you to remove it.
Remove the three ribbon cables connected to the bottom of the motherboard.
Use the plastic spudger to lift the white hinges from on top of the ribbon cables.
Then gently pull the cables out.
Bir başkası bu kılavuzu tamamladı.
