Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a Phillips head screw driver to remove the 13 screws in these locations.
Use a plastic spudger to pry up the bottom cover and remove it.
Use two fingers to unplug the battery-to-motherboard connection.
Take out battery by lifting it up in the manner pictured.
Unscrew screw holding SSD card in place.
Slide out the SSD card towards you to remove it.
Remove the three ribbon cables connected to the bottom of the motherboard.
Use the plastic spudger to lift the white hinges from on top of the ribbon cables.
Then gently pull the cables out.
Remove 4 connectors from the right side of the motherboard.
All of these connectors release by simply pulling back.
On the left side of the motherboard, remove one more connector and two cables.
To remove the cables, lift them up with a plastic spudger.
Remove the 2 fan screws and the 4 heat sink screws.
The screws don't necessarily need to be removed from the component, but rather just loosened enough to remove the component from the motherboard.
Now remove the fan/heat sink component.
Remove the 2 motherboard screws.
Now you can remove the motherboard.
Bir başkası bu kılavuzu tamamladı.
