Ana içeriğe geç
Acer Chromebook C720-2848 SSD Replacement
Neye ihtiyacın var
  1. Acer Chromebook C720-2848 SSD Replacement, Back Cover: adım 1, 2 resimden 1. Acer Chromebook C720-2848 SSD Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 SSD Replacement: adım 2, 3 resimden 1. Acer Chromebook C720-2848 SSD Replacement: adım 2, 3 resimden 2. Acer Chromebook C720-2848 SSD Replacement: adım 2, 3 resimden 3.
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 SSD Replacement, SSD: adım 3, 2 resimden 1. Acer Chromebook C720-2848 SSD Replacement, SSD: adım 3, 2 resimden 2.
    • Unscrew screw holding SSD card in place.
    • Slide out the SSD card towards you to remove it.
    • The SSD card is the blue chip on the right connected to the motherboard.
    • Be sure to store this screw apart from the others as it is a different length.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Robert Escobio
597 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S9-G3, Remmell Fall 2017 USF Tampa, Team S9-G3, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S9G3
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 530
