Ana içeriğe geç
Acer Chromebook C731-C8VE Speakers Replacement
Neye ihtiyacın var
  1. Acer Chromebook C731-C8VE Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Speakers Replacement: adım 2, 1 resimden 1.
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Speakers Replacement: adım 3, 2 resimden 1. Acer Chromebook C731-C8VE Speakers Replacement: adım 3, 2 resimden 2.
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Speakers Replacement: adım 4, 3 resimden 1. Acer Chromebook C731-C8VE Speakers Replacement: adım 4, 3 resimden 2. Acer Chromebook C731-C8VE Speakers Replacement: adım 4, 3 resimden 3.
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Speakers Replacement: adım 5, 3 resimden 1. Acer Chromebook C731-C8VE Speakers Replacement: adım 5, 3 resimden 2. Acer Chromebook C731-C8VE Speakers Replacement: adım 5, 3 resimden 3.
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Speakers Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
  7. Acer Chromebook C731-C8VE Speakers Replacement, Speakers: adım 7, 2 resimden 1. Acer Chromebook C731-C8VE Speakers Replacement, Speakers: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Unplug the speaker cable from the motherboard at the connection using a pair of tweezers.
    • Be sure to pull from the plastic casing, as pulling the wires might result in a damaged plug.
  8. Acer Chromebook C731-C8VE Speakers Replacement: adım 8, 2 resimden 1. Acer Chromebook C731-C8VE Speakers Replacement: adım 8, 2 resimden 2.
    • Using a nylon spudger, pry the speaker from the housing of the laptop.
    • There are no screws connecting the speakers, so you just need to pry the adhesive off of the board.
    • The adhesive will have some resistance, but the new speakers will have a new layer of adhesive on them. This means there is no worry about damaging the tape on the old assembly.
  9. Acer Chromebook C731-C8VE Speakers Replacement: adım 9, 2 resimden 1. Acer Chromebook C731-C8VE Speakers Replacement: adım 9, 2 resimden 2.
    • Unhook the cables connecting the two speakers from the anchor points on the device.
    • Since some of the anchor points are facing different directions, it is important to take it slow and unhook one point at a time.
  10. Acer Chromebook C731-C8VE Speakers Replacement: adım 10, 2 resimden 1. Acer Chromebook C731-C8VE Speakers Replacement: adım 10, 2 resimden 2.
    • Remove the speakers from the laptop.
Sonuç
Ethan Johnson
199 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 94
