Ana içeriğe geç
Acer Chromebook C731-C8VE Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 1 resimden 1.
    • Place Chromebook face down.
  2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 2, 2 resimden 1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2mm screws have washers and must be placed in these specific areas.
    • The 2mm screws marked orange do not have washers and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 3, 3 resimden 1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 3, 3 resimden 2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 4, 3 resimden 1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 4, 3 resimden 2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 4, 3 resimden 3.
    • Detach the two wires that connect the Wi-Fi card to the screen.
    • The white wire will attach to the top and the black wire to the bottom.
  5. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 5, 3 resimden 1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 5, 3 resimden 2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 5, 3 resimden 3.
    • Use the JIS #00 screwdriver to unscrew the single 1mm screw connecting the Wi-Fi card to the base.
    • Once the screw is removed, the Wi-Fi card will pop up.
  6. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 6, 3 resimden 1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 6, 3 resimden 2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: adım 6, 3 resimden 3.
    • Remove the Wi-Fi card from the motherboard.
Sonuç
Justin Menninger
385 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 172
