Ana içeriğe geç
Acer Chromebook C732 Screen Replacement
Neye ihtiyacın var
  1. Acer Chromebook C732 Screen Replacement, Safety First: adım 1, 1 resimden 1.
    • Make sure your device is turned off and disconnect your battery from the motherboard.
    • You can find a detailed guide for getting to and replacing this device's battery here
  2. Acer Chromebook C732 Screen Replacement: adım 2, 1 resimden 1.
    • Open the Chromebook so the display is facing towards you.
  3. Acer Chromebook C732 Screen Replacement: adım 3, 2 resimden 1. Acer Chromebook C732 Screen Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool or a spudger, carefully pry the plastic bezel around the screen.
    • If you start in the corner, you should be able to release the tabs there. Once those tabs have been released, you can release the rest by hand.
  4. Acer Chromebook C732 Screen Replacement: adım 4, 3 resimden 1. Acer Chromebook C732 Screen Replacement: adım 4, 3 resimden 2. Acer Chromebook C732 Screen Replacement: adım 4, 3 resimden 3.
    • Remove the four screws holding the display in place with a Phillips #1 screwdriver.
    • Carefully lower the display to rest on the keyboard.
  5. Acer Chromebook C732 Screen Replacement: adım 5, 3 resimden 1. Acer Chromebook C732 Screen Replacement: adım 5, 3 resimden 2. Acer Chromebook C732 Screen Replacement: adım 5, 3 resimden 3.
    • The display connector is located on the back and is covered by some adhesive tape.
    • Carefully peal the tape back
    • Once the tape is peeled back, you can lift the bar to disconnect the display cable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Mehnert
28.615 İtibar
43 adet Kılavuz yazıldı
Ekip
iFanatics iFanatics üyesi
Community
55 Üyeler
158 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 546
