Ana içeriğe geç
Acer Chromebook C740 LCD Screen Replacement
Neye ihtiyacın var
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: adım 2, 2 resimden 1. Acer Chromebook C740 LCD Screen Replacement: adım 2, 2 resimden 2.
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: adım 5, 2 resimden 1. Acer Chromebook C740 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: adım 6, 3 resimden 1. Acer Chromebook C740 LCD Screen Replacement: adım 6, 3 resimden 2. Acer Chromebook C740 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Grace Bassett
217 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G2, Livingston Spring 2017 Cal Poly, Team S22-G2, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G2
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 3,577
