Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Power down the Chromebook and disconnect the power adapter.
With the Chromebook open and face up, pry the black screen frame with your fingers.
Move slowly around the display to evenly remove it.
Once the frame is separated from the display, angle the display assembly back .
Lift up the portions of the frame covering the front two hinges with the spudger.
Remove the frame from the screen assembly by pulling the frame towards you.
Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
Place the LCD screen face down on the keyboard.
Remove the tape holding the black connector in place.
Unplug the connector with your hands.
7 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
