Ana içeriğe geç
Acer Chromebook C740 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook C740 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Motherboard Replacement: adım 2, 2 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 2, 2 resimden 2.
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Motherboard Replacement: adım 3, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 3, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    • Flip up the clip holding down the white cable using the spudger.
    • Pull the cable outwards towards the battery.
  5. Acer Chromebook C740 Motherboard Replacement: adım 5, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 5, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 5, 3 resimden 3.
    • Flip up the clip holding down the white cable using the flat end of the spudger.
  6. Acer Chromebook C740 Motherboard Replacement: adım 6, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 6, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 6, 3 resimden 3.
    • Flip up the white clip holding down the connector labelled "MB" using the flat end of the spudger.
    • Remove the connector by pulling out towards the battery.
  7. Acer Chromebook C740 Motherboard Replacement: adım 7, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 7, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 7, 3 resimden 3.
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  8. Acer Chromebook C740 Motherboard Replacement: adım 8, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 8, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 8, 3 resimden 3.
    • Unplug the black connector attached to the motherboard at the top right of the battery by using a spudger to push the two L-shaped indentations towards the battery.
  9. Acer Chromebook C740 Motherboard Replacement: adım 9, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 9, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 9, 3 resimden 3.
    • Peel back the tape covering the white connector at the top-right of the motherboard.
    • Remove the connector from its fitting by pulling outwards.
  10. Acer Chromebook C740 Motherboard Replacement: adım 10, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 10, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 10, 3 resimden 3.
    • Unplug the white connector attached to the right of the fan with the spudger by applying force towards the battery on the two L-shaped indentations.
  11. Acer Chromebook C740 Motherboard Replacement: adım 11, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 11, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 11, 3 resimden 3.
    • Disconnect the two white and black wires by holding close to the metal snap-on caps and pulling upwards.
  12. Acer Chromebook C740 Motherboard Replacement: adım 12, 2 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the four 3.7 mm screws with a Phillips #0 screwdriver.
  13. Acer Chromebook C740 Motherboard Replacement: adım 13, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 13, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 13, 3 resimden 3.
    • Loosen the two black screws with a Phillips #0 screwdriver.
    • These screws cannot be removed. However, simply loosening them allows the heatsink fan to lift away from the motherboard.
    • Lift the heatsink fan and rotate it away from the mother board to set down outside the laptop.
  14. Acer Chromebook C740 Motherboard Replacement: adım 14, 3 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 14, 3 resimden 2. Acer Chromebook C740 Motherboard Replacement: adım 14, 3 resimden 3.
    • Remove the 3.63 mm screw in the top right near the hinge with a Phillips #0 screwdriver.
    • Remove the 3.75 mm screw near the top right corner of the battery with a Phillips #0 screwdriver.
  15. Acer Chromebook C740 Motherboard Replacement: adım 15, 2 resimden 1. Acer Chromebook C740 Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  16. Acer Chromebook C740 Motherboard Replacement: adım 16, 1 resimden 1.
    • Unplug the solid state drive.
  17. Acer Chromebook C740 Motherboard Replacement: adım 17, 1 resimden 1.
    • Carefully lift the motherboard away from the laptop with two hands.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
William Yu
283 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G2, Livingston Spring 2017 Cal Poly, Team S22-G2, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 3,137
