Ana içeriğe geç
Acer Chromebook C740 Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Chromebook C740 Solid State Drive Replacement, Back Panel: adım 1, 1 resimden 1.
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Solid State Drive Replacement: adım 2, 2 resimden 1. Acer Chromebook C740 Solid State Drive Replacement: adım 2, 2 resimden 2.
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Solid State Drive Replacement: adım 3, 3 resimden 1. Acer Chromebook C740 Solid State Drive Replacement: adım 3, 3 resimden 2. Acer Chromebook C740 Solid State Drive Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Solid State Drive Replacement, Solid State Drive: adım 4, 2 resimden 1. Acer Chromebook C740 Solid State Drive Replacement, Solid State Drive: adım 4, 2 resimden 2.
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  5. Acer Chromebook C740 Solid State Drive Replacement: adım 5, 1 resimden 1.
    • Unplug the solid state drive.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Flor De La Rosa
875 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G2, Livingston Spring 2017 Cal Poly, Team S22-G2, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 62
Her zaman: 4,744
