Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Power down the Chromebook and disconnect the power adapter.
Place the chromebook bottom side up on a flat surface.
Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
Pull the black wire out from under the the black center clips and up from the gray outer clips with a spudger.
Use a spudger to lift the black clip on the small purple ribbon cable connector to the left of the touchpad.
Pull the ribbon cable out from the connector.
Remove the five 2.5 mm screws with a Phillips #0 screwdriver.
Remove the four 2.8 mm screws with a Phillips #00 screwdriver.
Remove the black tape on the left side of the touchpad.
Lift off the black plastic cover with the plastic opening tool.
6 farklı kişi bu kılavuzu tamamladı.
