Ana içeriğe geç
Acer Chromebook C740-C4PE Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: adım 1, 3 resimden 1. Acer Chromebook C740-C4PE Battery Replacement, Battery: adım 1, 3 resimden 2. Acer Chromebook C740-C4PE Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: adım 2, 1 resimden 1.
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: adım 3, 1 resimden 1.
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: adım 4, 3 resimden 1. Acer Chromebook C740-C4PE Battery Replacement: adım 4, 3 resimden 2. Acer Chromebook C740-C4PE Battery Replacement: adım 4, 3 resimden 3.
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jacob Kahn
273 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 479
