Ana içeriğe geç
Acer Chromebook C740-C4PE Heatsink Replacement
Neye ihtiyacın var
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: adım 1, 3 resimden 1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: adım 1, 3 resimden 2. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: adım 1, 3 resimden 3.
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: adım 2, 2 resimden 1. Acer Chromebook C740-C4PE Heatsink Replacement: adım 2, 2 resimden 2.
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: adım 3, 2 resimden 1. Acer Chromebook C740-C4PE Heatsink Replacement: adım 3, 2 resimden 2.
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: adım 4, 1 resimden 1.
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: adım 5, 1 resimden 1.
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: adım 6, 1 resimden 1.
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: adım 7, 1 resimden 1.
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dylan Tocci
237 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G4
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
What type of thermal paste is best used?
Tracey Arria - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 354
