Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
When the screen no longer functions like it should, it is best to replace it altogether with a new one. This guide will aid you in removing the screen frame, inside screws, and LCD screen.
  1. Power down the Acer Chromebook and disconnect  the battery adapter.
    • Power down the Acer Chromebook and disconnect the battery adapter.
  2. Use a spudger to pry the black screen frame off. It is recommended to start from the top corner.
    • Use a spudger to pry the black screen frame off.
    • It is recommended to start from the top corner.
  3. Use the spudger to open the two hinges that connect the screen frame to the bottom of the Chromebook. Move the spudger along the bottom of the screen frame until you can pull the frame out entirely.
    • Use the spudger to open the two hinges that connect the screen frame to the bottom of the Chromebook.
    • Move the spudger along the bottom of the screen frame until you can pull the frame out entirely.
  4. Use a #0 Phillips screwdriver to unscrew the four 3.35 mm screws. Use a #0 Phillips screwdriver to unscrew the four 3.35 mm screws.
    • Use a #0 Phillips screwdriver to unscrew the four 3.35 mm screws.
  5. Place the LCD screen on top of keyboard. Lift the tape that  holds the back of the LCD screen to the connector, and unplug the connector. Remove the LCD screen and replace with the new one.
    • Place the LCD screen on top of keyboard.
    • Lift the tape that holds the back of the LCD screen to the connector, and unplug the connector.
    • Remove the LCD screen and replace with the new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sang Huynh
240 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 284
