Ana içeriğe geç
Acer Chromebook C740-C4PE Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: adım 1, 3 resimden 1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: adım 1, 3 resimden 2. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: adım 1, 3 resimden 3.
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Solid State Drive Replacement: adım 2, 3 resimden 1. Acer Chromebook C740-C4PE Solid State Drive Replacement: adım 2, 3 resimden 2. Acer Chromebook C740-C4PE Solid State Drive Replacement: adım 2, 3 resimden 3.
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Solid State Drive Replacement: adım 3, 1 resimden 1.
    • Pull the Solid State Drive out of the connector.
Sonuç
Sang Huynh
252 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G4
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 749
