Ana içeriğe geç
Acer Chromebook C740-C4PE Touchpad Replacement
Neye ihtiyacın var
  1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: adım 1, 3 resimden 1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: adım 1, 3 resimden 2. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Touchpad Replacement: adım 2, 1 resimden 1.
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Touchpad Replacement: adım 3, 1 resimden 1.
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Touchpad Replacement: adım 4, 3 resimden 1. Acer Chromebook C740-C4PE Touchpad Replacement: adım 4, 3 resimden 2. Acer Chromebook C740-C4PE Touchpad Replacement: adım 4, 3 resimden 3.
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
  5. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: adım 5, 2 resimden 1. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: adım 5, 2 resimden 2.
    • Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
    • Lift the silver restraint from the device.
  6. Acer Chromebook C740-C4PE Touchpad Replacement: adım 6, 1 resimden 1.
    • Unscrew the five screws on the touchpad.
    • You will need to move aside the plastic covering that is above each screw.
  7. Acer Chromebook C740-C4PE Touchpad Replacement: adım 7, 2 resimden 1. Acer Chromebook C740-C4PE Touchpad Replacement: adım 7, 2 resimden 2.
    • Using a spudger, lift the black electrical tape to the left of the touchpad.
    • Remove the black wire running across the touchpad from the two hooks on top of the part.
    • Be careful not to damage the black wire when removing from the two hooks.
  8. Acer Chromebook C740-C4PE Touchpad Replacement: adım 8, 2 resimden 1. Acer Chromebook C740-C4PE Touchpad Replacement: adım 8, 2 resimden 2.
    • Lift the flap on the wire connecting the motherboard and remove the connector.
  9. Acer Chromebook C740-C4PE Touchpad Replacement: adım 9, 1 resimden 1.
    • Remove the touchpad from the device.
Sonuç
Jacob Kahn
273 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 292
