Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will show you how to replace a faulty battery in the Acer Chromebook CB3-111-C670.
  1. Be sure to have completely shut down the device before attempting to open it.
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Manta Tornavida Seti
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Pull the battery connector cable towards the battery to disconnect it.
    • Pull the battery connector cable towards the battery to disconnect it.
  5. Remove the battery.
    • Remove the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tony
438 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 42
Her zaman: 2,938
