Ana içeriğe geç
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: adım 1, 1 resimden 1.
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: adım 2, 2 resimden 1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: adım 2, 2 resimden 2.
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tony
459 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
no help i need help putting it on with out that
Simon Kuhn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 81
Her zaman: 7,202
