Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to replace the screen of your Acer Chromebook CB3-111-C670. The screen replacement is a simple fix, and shouldn't take long at all.
  1. Unplug and power off the laptop before starting this repair. Pry the white frame away from the screen with an opening tool.
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Remove the four screws within the silver brackets that are holding the screen to the back of the laptop. Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  4. Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  5. Pull the ribbon cable out with tweezers and remove the screen.
    • Pull the ribbon cable out with tweezers and remove the screen.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Allen Lewis
256 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Very easy. Thanks
johnqm123 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 4,094
