Ana içeriğe geç
Acer Chromebook CB3-111-C670 Screen Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-111-C670 Screen Replacement, Screen: adım 1, 2 resimden 1. Acer Chromebook CB3-111-C670 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Acer Chromebook CB3-111-C670 Screen Replacement: adım 2, 2 resimden 1. Acer Chromebook CB3-111-C670 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. Acer Chromebook CB3-111-C670 Screen Replacement: adım 3, 1 resimden 1.
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  4. Acer Chromebook CB3-111-C670 Screen Replacement: adım 4, 1 resimden 1.
    • Pull the ribbon cable out with tweezers and remove the screen.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Allen Lewis
259 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Very easy. Thanks
johnqm123 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 4,973
