Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Pry the white frame away from the screen with an opening tool.
Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
Once you've removed the screws, lift the piece of tape that is covering the display connector.
Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
Bu adımda kullanılan alet:Tweezers$4.99-
Pull the ribbon cable out with tweezers and remove the screen.
9 farklı kişi bu kılavuzu tamamladı.
