Ana içeriğe geç
Acer Chromebook CB3-111-C8UB Back Panel Removal
Neye ihtiyacın var
  1. Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: adım 1, 2 resimden 1. Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: adım 1, 2 resimden 2.
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Back Panel Removal: adım 2, 3 resimden 1. Acer Chromebook CB3-111-C8UB Back Panel Removal: adım 2, 3 resimden 2. Acer Chromebook CB3-111-C8UB Back Panel Removal: adım 2, 3 resimden 3.
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Back Panel Removal: adım 3, 2 resimden 1. Acer Chromebook CB3-111-C8UB Back Panel Removal: adım 3, 2 resimden 2.
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
Sonuç
Travis Vo
426 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-7, Maness Winter 2017 Cal Poly, Team 22-7, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G7
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
When I removed the screws from the bottom (Step 1), the 8 screws closest to the hinge were 7mm, and the front 4 were 5mm. Hope this helps someone in the future.
lumberjackdavid - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 1,628
