Ana içeriğe geç
Acer Chromebook CB3-111-C8UB Key Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-111-C8UB Key  Replacement, Key: adım 1, 3 resimden 1. Acer Chromebook CB3-111-C8UB Key  Replacement, Key: adım 1, 3 resimden 2. Acer Chromebook CB3-111-C8UB Key  Replacement, Key: adım 1, 3 resimden 3.
    • Slide the plastic opening tool under the key you wish to remove until it is up against the bottom part of the key.
    • Then, lever the plastic opening tool. It should catch the key.
    • Finally, keep levering the key until it pops out.
    • We do this to avoid depressing the key. It becomes much harder to catch the lip with the key pushed down.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To put the key back in place, simply push down on it until you hear the clips snap into place.
Bir başkası bu kılavuzu tamamladı.
Travis Vo
426 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-7, Maness Winter 2017 Cal Poly, Team 22-7, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G7
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 875
