Ana içeriğe geç
Acer Chromebook CB3-131-C3KD Keyboard Key Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: adım 1, 2 resimden 1. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: adım 1, 2 resimden 2.
    • Make sure you turn off the laptop before starting.
    • Place the flat head screw driver under the key, but over the key clip retainer.
  2. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: adım 2, 1 resimden 1.
    • Push down on one of the bottom corners of the key, so that the opposite diagonal corner rises and gives leeway.
    • Carefully place the flat head screw driver under the raised corner.
    • Carefully pry up from underneath the raised corner to raise the metal clips away from the key base.
  3. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: adım 3, 2 resimden 1. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: adım 3, 2 resimden 2.
    • Pry up from the top left and right corners of the retainer subsequently.
    • Remove clip retainer.
Sonuç
Johnathan
216 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G1, Passmore Fall 2017 USF Tampa, Team S11-G1, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G1
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
I mean… That’s half of the replacement… so there’s that.
Darren D. MacDonald - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 1,467
