Ana içeriğe geç
Acer Chromebook CB3-431-C5EX Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: adım 2, 1 resimden 1.
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook CB3-431-C5EX Battery Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: adım 5, 2 resimden 1. Acer Chromebook CB3-431-C5EX Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: adım 6, 1 resimden 1.
    • Carefully lift the entire battery pack out of the laptop.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Elsa Bassett
414 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G3
5 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - Yanıt
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 80
Her zaman: 8,730
