Ana içeriğe geç
Acer Chromebook CB3-431-C5EX Display Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-431-C5EX Display Replacement, Display: adım 1, 1 resimden 1.
    • Make sure the work area is clean and free from dirt and debris.
    • Open the lid of the laptop.
    • Place the laptop so the screen is facing upwards and the outside of the laptop is flat against a table.
  2. Acer Chromebook CB3-431-C5EX Display Replacement: adım 2, 2 resimden 1. Acer Chromebook CB3-431-C5EX Display Replacement: adım 2, 2 resimden 2.
    • Carefully insert an opening tool under the screen bezel and gently pry it away from the edge of the screen.
    • Slowly slide the opening tool around the bezel on all four sides to separate it from the screen.
    • Be careful to not damage any wires that are under the bezel, or crack the bezel itself.
  3. Acer Chromebook CB3-431-C5EX Display Replacement: adım 3, 1 resimden 1.
    • Remove the four 2.8 mm screws from the screen using a Phillips #0 screwdriver and place them to the side for use later.
    • Be careful to not touch the tape protecting the display circuit board.
  4. Acer Chromebook CB3-431-C5EX Display Replacement: adım 4, 3 resimden 1. Acer Chromebook CB3-431-C5EX Display Replacement: adım 4, 3 resimden 2. Acer Chromebook CB3-431-C5EX Display Replacement: adım 4, 3 resimden 3.
    • Gently lay the screen against the keyboard.
    • Carefully remove the adapter connecting the display to the motherboard.
  5. Acer Chromebook CB3-431-C5EX Display Replacement: adım 5, 1 resimden 1.
    • Once you have separated the screen from the motherboard, carefully remove the display from the laptop.
Sonuç
To reassemble your device, follow these instructions using a replacement screen, in reverse order.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 298
